Doing timing, work, balance, chain, crankshaft sprocket at 11 o’clock
Old Nov 10, 2024 | 05:21 PM
TurboKid1994's Avatar
Originally Posted by donbrew
The key should be a 12 o'clock. The mark should be at about 5:00.
There is a link to FREE service manuals in my sig.
I have never seen a 2.0 sprocket but, the2.2/2.4 does not have springs.
Here is a pdf of the procedure:
Attachment 49497
Took you up on your free shop manual, and it was EXACTLY what I needed.
Unlike oldblue I didnt cut my front timing cover gasket meaning I removed the engine mount! UGH! I had forgot which bolts went where ( 3 of them , 1 short )
Thank you so much!
Old Nov 10, 2024 | 07:43 PM
fastsuv's Avatar
Attachment 49497
I have replaced the timing and balance chains at least 4-5 times on LNF engines (HHR SS) and have never seen the sprocket with springs on any of them.
Steve
Old Nov 10, 2024 | 10:07 PM
Steve
I realized what caused mine to be out of time as pictured earlier… On the teardown , I used an impact gun to break the crank nut. Must’ve shifted the sprocket somehow. Just got done tightening it the right way, and oh my. I used all of my strength.
it has a GM part number that yields a service site with the part but it’s discontinued. I guess you could find them in a junk yard. But it would have to be the SS. All the kits have the wrong sprocket.
Old Nov 11, 2024 | 08:48 AM
PulpFriction's Avatar
ZZP recommends against changing Ecotec sprockets, say they never (or maybe rarely) see them in need of replacement.
Old Nov 11, 2024 | 12:45 PM
And that crankshaft balance chain sprocket in the LNF engine is not the same as the L61 or LE5 or LE9.
as we’ve discussed it is obsolete and nobody sells a replacement.
Old Nov 12, 2024 | 11:16 PM
  #26
Happy to report that my little SS is back up and running! Fired right up. Only complaint is a slight rumble, sometimes, after a short rev, it stutters a little bit. threw several codes earlier, timing advanced, etc. but one of the VVT solenoid’s wasn’t fully plugged in.
Old Nov 13, 2024 | 10:56 PM
  #27
Update on the post completion rumble at idle.
Turns out I had the VVT solenoids in the wrong sockets! Oops.
switched them around and MAAAAN is it smooth 😍
thanks guys
Old Nov 14, 2024 | 07:54 AM
  #28
Thanks for the update! Keep it clean and drive it often!
Old Nov 14, 2024 | 08:37 AM
  #29
Congrats on the fix.
Could you clarify the above statement? I don’t understand. And, can you do this job without removing the engine mount?
Remember to put SS in your profile. It’s important!
Old Nov 14, 2024 | 09:11 AM
  #30
I posted years ago about cutting the timing chain cover gasket. Eliminating the need to remove the engine mount bracket bolted to the engine, it is not that much to remove the 3 bolts
post #5 in this thread
https://www.chevyhhr.net/forums/prob...-advice-63506/
