Engine reduced
Let’s not over look , it could be as simple as a battery lobotomy, now that’s pretty easy! All you need is a 10 mm open box or combination wrench to remove the negative cable from the battery, it lives back beside your spare tire under the trunk mat , disconnect it for 30 minutes. Reconnect it and see what the CEL shows.
Your PCM lives under the front hood in the drivers side, there are black plastic covers to remove, it’s really not that complicated just follow simple steps
https://www.flashmastersecm.com/prod...in-ecm-pcm-ecu
Keep It Simple Sam , (originally another derogatory name for lack of intelligence) start with the easy to check cost effective things. If it’s still broke move on to the next step.
But if you throw parts at it , you might be surprised, it’s still broken!
donbrew
0
Mar 22, 2016 08:10 AM
chevhhrdummy
Sep 30, 2014 07:48 PM
ahuschka
Aug 25, 2013 07:22 PM
menance
Dec 22, 2010 06:14 PM
