Intermittant boost problem.
Old Feb 16, 2011 | 02:49 PM
Gone Blue's Avatar
Angry
Originally Posted by c2vette
My bet is that it is very likely the Wastegate Actuator (this is a solenoid with three ports on it, located near the turbocharger). A bad actuator can cause low boost and also uncontrolled full boost. Known problem if you look in the "recall" postings. I just replaced mine for an "overboost" condition, but the more common symptom is under or no boost due to a cracked fitting.
https://www.chevyhhr.net/forums/show...t=23231&page=2 go to Pip4520
My Stage 1 car had this similar problem last week. I would have no boost for the first 20 miles or so in the morning and then once the car got hot I had boost. The dealer traced the issue to a crack in the wastegate actuator housing. This item is not covered under the 100,000 mile powertrain warranty if you can believe that. I had to pay my deductible under my extended warranty. G.B.
Old Mar 23, 2011 | 10:54 AM
Gas Man's Avatar
Well I'll join in this thread...
Monday... drove to work... no problems
Left work 2 hours later to go to another location, nothing over 5.7# in all gears. Even thru a key cycle. Drove a bit like this. Turned off car again (2nd time).
Left the powder coating shop, same thing, turned a corner... boost was back.
Got off the highway, 5.7# boost in 1st gear fine in all others.
Day later, numerous key cycles, still low boost in 1st, fine in all others.
WTF over!
Car has stage 1, stock air filter/box/tubes.
Dropped it off at the dealership.
Old Mar 23, 2011 | 11:22 AM
bartSS's Avatar
the map sensor is my guess..
Old Mar 23, 2011 | 12:22 PM
Gas Man's Avatar
The lower map sensor from the intercooler to intake?? or do you mean the wiring to it?
Old Mar 23, 2011 | 01:09 PM
bartSS's Avatar
I would check the wiring first but yeah that one
Old Mar 24, 2011 | 06:18 PM
  #26
Gas Man's Avatar
Yeah I looked at it...
had wire loom over the wiring... check
Played with it, to no benefit.... check.
We'll see what dealer says.
Old Mar 25, 2011 | 07:18 AM
  #27
bartSS's Avatar
Yeah let them figure it out.
The sensor could be gone though too
Old Mar 26, 2011 | 11:41 AM
  #28
Gas Man's Avatar
I agree.
But seriously... a bad sensor in 9k miles. And why only in first gear?
Old Mar 26, 2011 | 11:56 AM
  #29
hyperv6's Avatar
I agree.
May not be a bad wire per say but if you get on it the engine torques up and the connector get smashed into the compressor. This can force a short or disconnect.
The wires on mine looked fine but the connector would come up and hit and it just would kill the power till we shimmed the IC forward to give it clearance.
I also had convoluted tubing over the wires and it still did it.
I suspect as engine mounts get older and the engine comes up highter more will have contact issues.
Old Mar 26, 2011 | 11:58 AM
  #30
Gas Man's Avatar
But it doesn't kill my turbo... it wont allow it to get over like 5.7#
