Looks like I might need a new cooling fan assembly...
Old May 10, 2018 | 07:52 PM
rlee63a4's Avatar
...based on all the related threads I've scanned.
My SS never over heated until today when I saw the temp gauge higher than normal. So, I checked the DIC, and temp was 230 degrees. Once I hit the highway, the engine temp slowly decreased and stabilized at ~188-189; just to be sure and somewhat concerned, I had turned the heater on full blast even though it was ~80 ambient. When I got off on my exited ramp, the temp started to slowly climb during the mile or so of stop-and-go to get home.
Once home, I found that the fan was not running neither at high temp (219+ degrees) nor with the A/C on. Fuse is good. No relay on SS as far as I can tell. I plan to check the fan wiring in the morning, but, unless I find an obvious wiring/ground issue, I may need a new cooling fan assembly.
What say you? I always look to you guys to confirm what I think I know.
Regards,
Ron
P.S. I really enjoy driving my HHR SS, but it seems like I'm always fixing stuff, most significant to date includes the horrible GMTU sensor wiring, more recently a broken timing chain guide, and now a cooling fan??
Old May 10, 2018 | 08:23 PM
Did you see this thread? They talk about bypassing the module as a test.
https://www.chevyhhr.net/forums/hhr-...rent-ss-50941/
Old May 10, 2018 | 09:02 PM
The module seems to be available by iself these days.
Old May 11, 2018 | 06:18 AM
rlee63a4's Avatar
Thanks. I missed that particular thread in my haste, but was planning to use one of my jump starters to apply 12 volts to the fan motor.
Rock Auto has modules for $116 and complete fan assemblies with module for $159. So, it may be worth it to replace the whole enchilada except the fan assembly R&R would be more difficult.
I'll be back with the results...
Old May 11, 2018 | 07:15 AM
Don’t forget the discount code!
Old May 11, 2018 | 08:18 AM
There is 1 on ebay for $74.99, if you are not skeered.
https://www.ebay.com/itm/Engine-Cool...oAAOSwMtxXrp69
Old May 11, 2018 | 09:31 AM
rlee63a4's Avatar
Fan works. So, going for the $75 eBay control module. Doesn't skeer me in the least. All my cars are powered by eBay...
Old May 18, 2018 | 05:16 PM
rlee63a4's Avatar
eBay fan control module arrived today. I installed it, and the HHR is back on the road again--Plug-and-Play.
Old May 18, 2018 | 06:08 PM
Sweet!
Old May 18, 2018 | 06:32 PM
Awesome!
jmm121783
Jul 18, 2014 10:17 PM
camaro98z28
Sep 23, 2011 02:33 PM
urbexHHR
Mar 1, 2010 10:11 PM
SDV
Sep 30, 2009 07:13 AM
DANSHHR
Apr 15, 2009 07:15 PM
