New to forum, stage 1 kit issues...
Thanks ATL, that makes more sense. May be worth it to try the dejon spring first. I need to call the tech and see which part they're recommending to change. I didn't realize the solenoid and valve were separate. The quote i got was $190 which seems really high for either of those parts.
The intermittent nature of this problem is making it difficult to talk to the dealer. I've been able to give the tech a detailed description of the indications. They haven't been able to recreate the problem and are reluctant to go further, that's why I called chev customer assistance. I've given them plenty of P0101 codes to clear, but they haven't been able to see/hear the problem.
you should be able to bypass the whole solenoid altogether by rerouting the vacuum lines and replacing the solenoid with a t fitting. the vacuum lines and solenoid are supposed to look like the picture below. reroute them to look like the picture above and pull the solenoid and put a t fitting in its place
i would try the vacuum tank bypass first then the vacuum lines will be where the need to be to simply replace the solenoid with a t fitting. long term.....dunno....i would at least replace the faulty solenoid and possibly leave the vacuum tank bypassed
http://www.crateenginedepot.com/stor...P9076C137.aspx
I still bet it's the way the stage one was wired and unless the wires are completely sealed, soldered or not, they will short and throw a code.
The only other suggestion I have is the mechanical fuel pump.
Mine went out at 21k miles.
Still, I would start fresh on the stage 1 wiring.
I like this car, but chevy put some cheap parts in it.
The other day I was looking at the turbo setup of my EVO 8 compared to the SS and the EVO is all business and metal, the SS has a lot of tin and plastic.
IMO
Hey dmdreese-
Did you car ever run perfect with the GMTU installed? or has it always ran the way your describing? The reason I ask is because mine ran fine for about the first 2 months with the upgrade...then one day...it fell flat on it's face...been having problems ever since then. Is your problem like that as well?
Mine ran great for about a year and a half before it starting acting up. Have had the stage one wires soldered, a new MAF sensor installed, intake cleaning and vacuum test the entire system. I just wired in a vacuum gage into the line from the solenoid to the bypass valve. This way I'll be able to see what vacuum signal the bypass valve is getting when it acts up. Trying to eliminate either the solenoid or the bypass valve. Next step after this is to run a circuit tester out to the solenoid to see if its getting power when its acting up.
