New HHR SS OWNER NEEDS HELP
thanks for that confirmation rj. I am thinking I should get a new maf. Anyone object? I can read my maf readings on scanner and it moves when air moves but I wonder if it's not reading it correctly or it's very sporadic with its air thats why my afr bounces. I have tried cleaning it. I might even do another boost leak test if anyone thinks that might be it still. It did feel like it took the computer way longer to pull code after new o2s.
Fwiw.
The AF readings on mine seem to do the same thing. All over sometimes and steady other times. No running issues with mine and no codes being set.
I've tried cleaning the MAF sensor...no change. I think it's something to do with the GMTU tune on mine. I just live with it and try not to turn the RPD unit to the AF ratio screen.........
Thank you Robert I will look into those. Well never mind I just edited this. It is 2.3-6 for idle. Which mine is. Still might replace.. then atleast I know
Sounds like you may want to analyze the freeze frame data then. It could give you a clue as to what is going on. I could post all the conditions that must be met for P2178 to be triggered, if nobody has yet.
Robert
Robert
well I got my ltft -25 ish short term seems ok at idle but under acceleration it is -3 to -7.
