New HHR SS OWNER NEEDS HELP
Old Oct 6, 2021 | 08:57 PM
  #111
The wire looks like it is awfully close to the pipe.
Old Oct 6, 2021 | 09:00 PM
  #112
Cjonez1993's Avatar
I tucked it after I took pictures. I was mid working on it and thought pictures made sense then.
Old Oct 6, 2021 | 09:08 PM
  #113
Yes it does appear to be the factory cat.
Old Oct 6, 2021 | 09:17 PM
  #114
Cjonez1993's Avatar
thanks for that confirmation rj. I am thinking I should get a new maf. Anyone object? I can read my maf readings on scanner and it moves when air moves but I wonder if it's not reading it correctly or it's very sporadic with its air thats why my afr bounces. I have tried cleaning it. I might even do another boost leak test if anyone thinks that might be it still. It did feel like it took the computer way longer to pull code after new o2s.
Old Oct 6, 2021 | 09:40 PM
  #115
Fwiw.
The AF readings on mine seem to do the same thing. All over sometimes and steady other times. No running issues with mine and no codes being set.
I've tried cleaning the MAF sensor...no change. I think it's something to do with the GMTU tune on mine. I just live with it and try not to turn the RPD unit to the AF ratio screen.........
Old Oct 7, 2021 | 05:25 AM
  #116
rorr's Avatar
GM is very specific on what to do for P2178. Attached are the pages from the service manual. It gives specific readings for the MAF and Map sensors. Maybe this will help.
Robert
File Type: pdf
Old Oct 7, 2021 | 06:11 AM
  #117
Cjonez1993's Avatar
Robert
Thank you Robert I will look into those. Well never mind I just edited this. It is 2.3-6 for idle. Which mine is. Still might replace.. then atleast I know
Old Oct 7, 2021 | 06:23 AM
  #118
rorr's Avatar
Sounds like you may want to analyze the freeze frame data then. It could give you a clue as to what is going on. I could post all the conditions that must be met for P2178 to be triggered, if nobody has yet.
Robert
Old Oct 7, 2021 | 06:49 AM
  #119
Cjonez1993's Avatar
Robert
well I got my ltft -25 ish short term seems ok at idle but under acceleration it is -3 to -7.
Old Oct 7, 2021 | 06:50 AM
  #120
Cjonez1993's Avatar
How long should I unplug the fuel pump fuses and let sit before I test to start to see if injectors are leaking?
