New IC
Old Jul 10, 2012 | 08:06 AM
  #31
I wonder why some company can't make some replacement metal ends for the stock IC.
Old Jul 10, 2012 | 09:03 AM
  #32
rallycobalt06's Avatar
because for the same cost you can get an entire upgrade...... i asked ZZP about this last year.
Old Jul 10, 2012 | 10:53 AM
  #33
Makes sense. I guess if it was a mass produced item, the price wouldn't be as much as a new IC. But a specialty item I could see the high cost.
Thanks for the answer rallycobalt06.
Old Jul 11, 2012 | 08:12 AM
  #34
Vcode455's Avatar
Plus you really don't want to uncrimp the aluminum header to remove the tank and then recrimp one on. You will weaken the crimp joint. I suppose you could weld the new tank on though. You might be able to glue on a stiffening rib to help.......
Old Jul 11, 2012 | 09:29 AM
  #35
foolmoon_design's Avatar
the chemical weld process will degrade the ABS if you try and glue a rib to it.
Several DOD companies, as well as Myth Busters have experimented with spray on bedliner as a anti-fragment/deforming component to armour and bunkers. It apparently adds a great amount of strength to whatever it is applied to, and adds an ability to absorb tremendous ammouts of shock/flex before deforming. This could be a cheap fix.
Old Jul 11, 2012 | 11:50 AM
  #36
Vcode455's Avatar
I think the tanks are glass filled nylon.........
Old Aug 4, 2012 | 02:59 PM
  #37
frdfandc's Avatar
Originally Posted by chevymanls6454
I cant seem to find a place that knows what the hell I'm talking about
Check into Williams Chevy here in Elkton. I picked up my SS back in March from them and it already had the GMS1 installed. All service work was completed there since new by the previous owner. And I checked the wiring. They were soldered and heat shrink applied over top, along with the black plastic tubing to protect the wiring.
If you see an Orange SS, it's me.
Old Aug 4, 2012 | 06:00 PM
  #38
[IMG]http://i125.photobucket.com/albums/p77/frdfandc/2012-03-08095539.jpg[IMG]
do you work in or frequently visit the shopping center behind Best Buy & Olive Garden in Christina, DE across from the hospital? if so, i see you all the time.
