No crank
Old Feb 24, 2024 | 10:13 AM
No just that spark plug for that cylinder. As I suggested, clean it, inspect it for cracks , corrosion
Old Feb 24, 2024 | 10:17 AM
No.
As I stated above, find yourself a good mechanic. ANY smoke coming from the wiring is BAD. You risk catching the car on fire if you continue to try to start it.
I speak from 30 years as a firefighter and former mechanic that used to specialize in automotive wiring problems.
Old Feb 24, 2024 | 10:38 AM
Your picture #4 is relay #34. #43 is a fuse for the ECM, #51 is the run/crank relay.
Old Mar 2, 2024 | 11:17 AM
PulpFriction's Avatar
Originally Posted by Alcutcha
Car will not crank, these are the codes I got last time the engine was running
P2626-00- Hos2 Pump current trim circuit Sensor 1
P2297- hos2 performance fuel cut Sensor
B1325-03- control module power circuit low voltage
P2929- i think was D acceleration fuel cut off circuit sensor 1
The owners before myself, had the recall work done to the ignition key, and the fuel pump issues.
I have replaced the battery and negative cable recently.
Pics
With awareness that it's been a few days -
From these forums
https://www.chevyhhr.net/forums/prob...r-14259/page2/
GM's DTC descriptions are:
P2297 HO2S Performance During Decel Fuel Cut-Off (DFCO) Sensor 1
P2626 HO2S Pumping Current Trim Circuit Sensor 1
B1325 Device Power 1 Circuit
No mention of P2929 - maybe an error?
Don't know why any of these would cause no crank. Betting a short in or near that coil pack blew a fuse or relay. IDK why that would cause a no crank. I would like to know what DOES happen when the key is turned to run, and when it's turned to start.
Looking forward to the rest of the story.
Luvmychevy03
Feb 4, 2023 06:34 AM
KenK
Mar 13, 2022 08:10 PM
Dunpokethebear
May 13, 2016 10:06 PM
cole81
Jan 27, 2016 01:25 PM
