Rough idle, hesitation, 0304
Old Jun 17, 2015 | 04:30 PM
Originally Posted by JJfly
Yes my post is related to previous post. I'm not fluent in internet forum stuff so a little help will go a long way.
There ya go - merged -
Old Jun 19, 2015 | 12:14 PM
JJfly's Avatar
Sweet. Thanks whopper
Old Jun 19, 2015 | 12:29 PM
JJfly's Avatar
so ask that mechanic to check the aforementioned electrical problem sources.
[/QUOTE]
That's just it. He DID check these connections and sources and found nothing. He said it needs traced even farther and that is not something i'm willing to risk doing myself. I think i'm either going to cut my losses and sell it or hang on to it and hope the cel comes on again soon. I get in a ****ty mood every time i get behind the wheel of this thing because it runs so bad and it used to run so good.
Old Jun 19, 2015 | 04:21 PM
And the results of the compression and leakdown tests?
Old Jun 20, 2015 | 09:32 AM
did you ever decarbonize the engine, Hurst2001 did his and had great results! the P0304 code has been cleared up for approximately a year now.
Old Jun 21, 2015 | 04:39 AM
  #26
hurst2001's Avatar
Yes had the same code .. Go get some techron and run it a few times in the tank put in when the gas is low and then fill up.. And sea foam too did this and not had a lite for year .. It seams like this engine like to build up carbon on the valves maybe cheap gas ...
Old Aug 1, 2015 | 09:19 AM
  #27
JJfly's Avatar
update
Ok so i've run a couple cans of seafoam through it. But more importantly, i unplugged one of the fuses for the abs system and haven't had any hesitation since. So, looks like i've got it narrowed down to an electrical issue somewhere with the abs. Thought that was interesting. Any thoughts?
Old Aug 1, 2015 | 09:55 AM
  #28
Plug the fuse back in to test your theory
Old Aug 6, 2015 | 05:35 PM
  #29
JJfly's Avatar
yup did that. confirmed
Old Aug 6, 2015 | 06:16 PM
  #30
So, you are saying the ABS system is causing a misfire in cylinder #4 (P0304)? Or, disabling the ABS keeps the ABS light from coming on because you have a misfire in cylinder #4?
I'm getting really confused. I don't know what the problem is a misfire or the ABS. Has anybody checked the ABS wiring or even put a tool on it?
A persistent misfire will make the T/C and ABS lights come on. Is that what we are dealing with?
The ABS system won't cause a misfire.
You can have enough misfires to cause trouble lights and you would never notice. The computer is trying to protect the (1)Calalytic Converter and the (2)people in the car.
Did you ever separate the UBEC halves? Did you ever inspect the ECM connector? At 105K it would not hurt to think about the VVT valves, they may be getting close to bad.
