RPM does not reduce when shifting
Old 02-24-2018, 04:38 PM
Chet043's Avatar
I see this is quite old but I just purchased a 09 ss that hangs after gas is released and clutch is pressed. What ever rpm your at when you push the clutch in it just hangs there for a second or two. Looks like I don’t know how to drive a stick been driving one for years never had a car act like this
Chet043 is offline
Old 02-24-2018, 07:42 PM
Technical Moderator
Does the pedal return?
Any CEL?
Dirty throttle body?
donbrew is offline
Old 02-24-2018, 07:46 PM
Technical Moderator
Since this really had nothing in common with the thread it was attached to, I dstarted a new thread.
donbrew is offline
Old 02-24-2018, 11:38 PM
I had the same issue, here's the thread.
https://www.chevyhhr.net/forums/prob...-issues-50825/
RJ_RS_SS_350 is offline
Old 11-18-2018, 11:56 AM
LT1GMC's Avatar
I have had the same issue since new on my 08 HHRSS Manual. Seems to do it worse when the engine is heat soaked, like in a drive thru line then leaving. Rpm's hang high after the throttle is released for a couple of seconds. Did it before and after the Stage kit install in march of 08, does it now but a bit more often at 91,000 miles. I have replaced ECM, ECM Program, throttle body and throttle position sensor, gas pedal assembly and electronics, MAP sensor, and checked all lines and hoses. Seems like its something in the ECM programming, as an emissions cycle or something. Have not been able to find anything else. SS runs great and has has no other issues. If anybody else finds the cause please advise.
LT1GMC is offline
Old 11-18-2018, 12:43 PM
As noted in the thread I linked to, the problem has not returned for me. Try swapping the brake pedal position sensor with the clutch pedal position sensor, or installing a new clutch pedal position sensor. I think that's what fixed mine, or it just coincidentally fixed itself.
alfolsee2000
03-11-2022 09:22 PM
jekltm
07-15-2013 02:16 PM
crazybob
08-29-2006 10:42 PM
Quick Reply: RPM does not reduce when shifting
