Shifter cables
Old Feb 27, 2013 | 07:21 AM
How would a new shifter cable affect the position for reverse? Wouldn't that require at least a new shifter assembly, if not a different trans?
Wouldn't habitual premature shifting into 5th gear cause lots of clutch wear?
Old Feb 27, 2013 | 07:25 AM
B.Diggity's Avatar
Well last night I had to drive it and so I beat the shifter knob a few times and its fixed tge gear problem and doesnt smell like burning clutch anymore. So I will keep her and see how it goes.
But on a side note, now it is leaning to the left. It used to sit in the middle, not anymore. Can anyone verify that they did change the part number on the shifter assembly?
I still dont like how 5th gear isnt above reverse though. Itll take a while to learn the new placement.
Old Feb 27, 2013 | 07:27 AM
B.Diggity's Avatar
Well reverse is in the old spot but all the other gears are closer to eachother. And its not really premature shifting. It has no problem going into 5th at 35mph. It has no lugging or slowness.
Old Feb 27, 2013 | 08:20 AM
"so I beat the shifter knob a few times and its fixed tge gear problem and doesnt smell like burning clutch anymore. So I will keep her and see how it goes."
Burning clutch smell and you're OK with that? Not me if it was mine.
Old Feb 27, 2013 | 09:05 AM
B.Diggity's Avatar
They wont replace it. Already been down that road with the first shifter replacement and i dont have the money to replace it. Might let it sit til it goes and just upgrade to stage 1.5
Old Feb 27, 2013 | 09:41 AM
B.Diggity's Avatar
Also on a side note anyone know how to remove the shifter knob? Ive looked everywhere but cant find the ss removal instructions
Old Feb 28, 2013 | 07:52 PM
B.Diggity's Avatar
'Kay, just a quick update. Ive grown to like this shifter. Its alot more tight. Gears are closer so its faster to switch gears. Still hate 5th though but im try to use it only at the higher speeds, ie 45-50, so im not over stressing anything. :) but yea, this is how they should have felt from dealership. Js
bdlabaere27
Jul 10, 2013 01:13 AM
B.Diggity
Apr 27, 2012 03:26 PM
djr1973
13
Apr 24, 2010 02:45 AM
laylowcustoms
May 20, 2006 01:46 AM
