Stuck Bolts
Old Sep 9, 2011 | 02:13 PM
nacademus's Avatar
MAPP Gas.
Old Sep 10, 2011 | 06:56 PM
foolmoon_design's Avatar
thanks for everyone's response.
This was tha outcome. very tight space to work in.
Tried the blow torch method after a few spirited runs around the block..... Only burnt my wrist, bolts still stuck!
Next, tried some penetrating oil, nothing. Wrist still burnt!
I went out and bought an Impact driver 100fpt.... nope. Jammed finger to add to burnt wrist
debated spending the coin on a 275fpt impact driver...... while driving back to Harbour Freight, noticed Kustum Kar Kare Muffler (I know, you should see the sign with those 3 k's lined up, and they are a chain!) Anyway, 10 minutes and 30 bucks later, bolts undone, and DP installed. I'm keeping the other Impact wrench for light stuff, but as my mods increase, I will be buying that 275fpt model for sure! Just erks me bad, that I was unprepared, to tackle such an easy change over, since I had no problems the first time. Still scratching my head, the bolts didn't look that bad. Tech said they were pretty tight, christ I was only using a ratchet and extension with a tourque bar for finishing. How they got above 100fpt is beyond me, unless thermal strech chinched it up????
Old Sep 10, 2011 | 07:15 PM
Nice work you Got-R-Done !! Use a little pure Tea Tree oil on those burns,it kills the germies and heals fast. ,
Old Sep 10, 2011 | 07:27 PM
bk94si's Avatar
Or you could pay a shop to loosen them up for you. I've done that before.
macarchie
Aug 4, 2014 08:50 AM
BZERKED
7
Sep 2, 2013 01:59 PM
retrolled
12
Feb 16, 2011 09:00 PM
JT's HHR
Jun 29, 2007 03:59 PM
