Stumbling at acceleration
Old Aug 7, 2020 | 09:38 AM
Ohiocruiser's Avatar
Coked intake valves?
Old Aug 7, 2020 | 09:49 AM
Originally Posted by Ohiocruiser
Cooked intake valves?
Cooked ? Or did you mean coked ?
Either way. That is a possibility. May be in need of that walnut shell media blasting.
Old Aug 7, 2020 | 10:43 AM
Good idea, a compression test may shed some light.
Old Aug 7, 2020 | 10:48 AM
oops. Sometimes Google spell check is making it worst.
Old Aug 10, 2020 | 09:43 AM
Lethal Tendencies's Avatar
Throttle body is a pain on the SS.
The charge pipe has been almost welded to the throttle body every time I worked on it.
Best way I found was this:
1. Disconnect the electrical connectors at the throttle body and lower MAP sensor.
2. Remove splash guard for access to clamp on charge pipe to intercooler.
3. Remove clamp and charge pipe from intercooler.
4. Remove 4 bolts that attach throttle body to intake manifold.
5. Remove throttle body/charge pipe assembly from vehicle.
6. Separate charge pipe from throttle body.
After cleaning, reassemble in reverse order.
thanks
Spike421
Feb 21, 2021 01:42 PM
slonny
Oct 24, 2019 03:44 PM
jay loukakis
Maintenance and Upkeep
18
Dec 21, 2013 12:00 PM
working on it
Sep 5, 2013 11:37 PM
Zagohhr
2.4L Performance Tech
14
Aug 27, 2013 12:39 PM
