Swapping turbo today
Old Jun 7, 2023 | 01:31 PM
greg8453's Avatar
Originally Posted by hhrumadbruh
Would this be the cause of 4 psi boost and exhaust smoke? Loss of oil and coolant?
It could do all that. Coolant?
Old Jun 7, 2023 | 03:02 PM
Loss of boost, exhaust smoke, oil loss - yes
I haven't been able to find an exploded diagram that shows the coolant passages in the K04, so coolant loss- unknown, maybe.
Old Jun 7, 2023 | 03:29 PM
fastsuv's Avatar
Here is a "general" turbocharger diagram showing the coolant and oil passages.
The coolant runs through a cavity in the turbo housing around the center area where the bearings are, more toward the exhaust side where there is greater heat.
I don't think a loose bearing or seal anywhere would allow coolant to leak inside the turbo.
Steve
Old Jun 8, 2023 | 02:30 PM
hhrumadbruh's Avatar
Thanks for the info Steve.
Got 3/4 of the exhaust studs out. Going to dealership for the one that was stripped.
Does anyone happen to have a part # for the oil and coolant banjo bolts that go into the turbo?
I would like to replace them while I swap the turbo if the dealership has them
Wasn't able to find anything on rockauto or Google.
Old Jun 8, 2023 | 05:31 PM
The gaskets are in your thread that I linked to. You're replacing the bolts too? If you're going to the dealer they have the part numbers.
Old Jun 8, 2023 | 08:41 PM
  #26
PulpFriction's Avatar
If you're going to the dealer parts department, just give them your VIN and they can tell you with great certainty what the correct P/N is.
hhrumadbruh
10
May 18, 2023 02:42 PM
badassbowtie
"How To" Tutorial Library
44
Jul 23, 2017 01:39 PM
LT1GMC
Jun 8, 2016 05:54 AM
foolmoon_design
2.0L Performance Tech
33
Jan 13, 2011 05:48 PM
JJ's BLACK SS
Dec 23, 2009 10:51 PM
