Vibration in motor WAWAWAWAWA !
Old Feb 23, 2016 | 02:16 PM
  #91
dhare1's Avatar
Yes, they were at 4 o'clock exhaust and 8 o'clock intake and after turning the crank 360 degrees they ended at 10 exhaust and 2 intake. With of course the crank at TDC.
Old Feb 23, 2016 | 02:32 PM
  #92
Don't worry about the crank at TDC if all of the marks line up it has to be at TDC.
Old Feb 23, 2016 | 02:54 PM
  #93
dhare1's Avatar
That's the answer I was looking for "If all the marks line up it has to be at TDC" All my marks line up including balance chain so I must have it right. I turned the crank by hand a few times and don't feel anything binding up so I'll start putting it back together and in a few more day's I'll start it up. Thank you very much .
Old Feb 27, 2016 | 05:01 PM
  #94
dhare1's Avatar
I have an update on the project , car started right up and no more vibration ! The slack on the balance shaft chain must have caused it to jump a few teeth and the shafts were out of time . I also installed all 4 motor/transmission mounts , 2 were bad . Thank you to everyone that helped me out , I enjoy learning . I'm sure you'll here from me again , there are a few other things I would like to do in the future.
Old Feb 28, 2016 | 07:02 AM
  #95
DrLoch's Avatar
Glad you go it fixed and thanks for reporting your results, this information can help someone else in the future.
Old Feb 28, 2016 | 10:14 AM
  #96
X2! Thanks for the follow up!!
paireno
Jun 1, 2008 12:45 AM
vschriver
May 14, 2008 11:26 AM
xzombiex66
Mar 28, 2007 05:44 PM
Rickh
Oct 13, 2006 05:21 PM
