Weird intermittant loss of power
Old Oct 20, 2012 | 10:24 AM
Tominator's Avatar
Originally Posted by SS fan
Let me guess, it's not a SS.
That's it in a nutshell...Seat height. Getting in and out was a pain. I'm 58 and in good shape but I'd bet just this cost a lot of potential sales with the customer base becoming older. The engine buzzed through the steering wheel noticeably in first and second. VERY weak acceleration in the higher gears. When it kicked down the RPM shot up but gaining speed was S...L...O...W...! No cruise control? Really? That alone would stop me from ever even considering this particular automobile.
Noticed a slight hesitation at cruise in lower RPM range. Lost a couple MPG. That went on about a week. Finally got CEL. Scanned via Torque Pro and el cheapo blue tooth adaptor.
Fault Log Manager reported P0236-Powertrain Turbo/Supercharger Boost Sensor "A" Circuit Range/Performance.
Zero boost at this point. Reset CEL and boost came back but symptoms returned in a couple days. Used Onstar to connect to my dealer and they transferred faults to dealer.
Other than being without my SS for a little over a week, getting the work done was painless. Kudos to George Weber!
Old Oct 20, 2012 | 08:09 PM
pitbull76's Avatar
That doesn't sound quite like whati have had.it's much more intermitten. In fact sincei wrote this post it hasn't acted up. I'm sure it will again soon though.
Old Nov 23, 2012 | 03:45 PM
Hotrodbob's Avatar
My SS has done the same thing. Dealer is stumped, but that's only part of the problem. 9 codes set the last time.
Now as far as the Crappy Cruze... 1/2 the HP, only 2-4 mpg better at best. No sport options so it handles poorly and cost the same new as my SS did. Other then that its a great car for someone else.
Old Nov 23, 2012 | 08:23 PM
pitbull76's Avatar
Well mine has actully behaved for the most part lately. I bought a bluetooth OBD2 adapter almost a month ago and then the car didn't act up. I haven't had any problems, but I did actually find a pending code P0099 on there today; That may be related to my issues but I'm not sure as the car was driving fine all day.
While I was checking the car over today though I noticed that the coolant was low. I check it periodically so this is a new development. I'll have to keep an eye on that now and hopefully it's just a small external leak that I haven't found yet. Otherwise this car may have to go. I've about had enough with it.
Old Nov 24, 2012 | 12:26 AM
Hotrodbob's Avatar
A co-worker just had the same coolant issue last week. He has a cracked block/head and they are changing out the engine.
Old Nov 24, 2012 | 08:10 AM
pitbull76's Avatar
Bob, thats the kind of repair I'm afraid of. I've had coolant usage twice before like this on previous cars. once turned out to be a head gasket and on the other car it was an intake gasket slowly leaking.
Old Nov 24, 2012 | 09:10 AM
Hotrodbob's Avatar
I agree. He is still in warranty so the cost is $0. This is expensive and if you are out of warranty it would be devastating.
Old Nov 24, 2012 | 12:47 PM
pitbull76's Avatar
Yes. At least I still have powertrain warranty for a few more months. If I have to add more, it'll make a trip to the dealer for sure.
Old Nov 27, 2012 | 12:33 AM
Hotrodbob's Avatar
Ok, the dealer didn't call me so I called them. Good news(?) engine runs great....so far, but they really didn't get to drive it far because the Tech broke the shift cable on the test drive. Parts on order.. been down since Nov 9th now. Once I get it back it will be time to move on to an old car I can work on... I'm done with the HHR...I can't afford a $20k paper weight.
Old Nov 27, 2012 | 09:55 AM
@Hotrodbob, I’m sorry to read about your unhappiness with your HHR. Do you know what kind of vehicle you’ll in the market for?
