Wheel loose, shaking when not turning
Old Feb 11, 2023 | 09:41 PM
greg8453's Avatar
The steering wheel wobbles while driving straight. I don't think she wants to be under the vehicle while it's being driven. I wouldn't recommend this course of action.
He's not driving it in the video. You must not think much of me to suggest what you did.
Old Feb 12, 2023 | 08:17 AM
geg's Avatar
geg
play in the steering wheel is a common disease on our car, the problem is in the weak cordan joint of the steering column. It is treated by replacing the cordan or column assembly.
RJ_RS_SS_350 mentioned tires and it went unnoticed. It is necessary to look at the tires, and also at the rims. A bent or deformed rim or bulges in tires can give the steering wheel a vibration effect when driving, and this vibration actually disappears when turning. Even a buildup of dirt on the inside of a wheel rim can have this effect, I had it once.
More brakes... I won't name the mechanism of how curved brakes are reflected in the vibration of the steering wheel, but it is reflected. I had this too and it ended after applying a front brake repair kit and changing the brake pads.
You can also look at the stabilizer bushings, but this is an unlikely cause. The first thing I would do is take off and spin the wheels.
Old Feb 12, 2023 | 01:19 PM
Sorry, not sure how I missed the video, looks like others missed it too. Definitely not tires or wheel weights or anything like that. Oldblue was correct, that's a steering component. And looking while an assistant turns the wheel, like in the video, could indeed reveal the issue
Old Feb 12, 2023 | 04:33 PM
greg8453's Avatar
You're OK. It's easy to miss things in here. I do it on a regular basis.
Bonez
Dec 20, 2022 07:20 AM
littlehoov
Dec 18, 2021 05:01 PM
Kingcorrupter
Feb 14, 2015 05:57 PM
hhrlover101
Oct 27, 2012 08:18 PM
thegodfather
Jun 27, 2011 10:26 AM
