15 inch rims and tires???
Old 08-14-2011, 04:31 AM
ebritt's Avatar
Question 15 inch rims and tires???
Is there a 15 inch rim out there for the HHR? If so what tires size would be recommended?
I want a set of 15s so I can put a tire with a taller sidewall on and get a softer ride.
ebritt is offline
Old 08-14-2011, 08:24 AM
tntwolt's Avatar
may not clear brake rotor. only way to get "soft" ride nowdays is to get an older linc towncar. had one a few years back and you could fall asleep driving it, so smooooth!
tntwolt is offline
Old 08-14-2011, 09:35 AM
The 15" rims from the 04-08 Malibu will work for you, and 205/65/15 tires will be within .08% of the stock size in overall diameter so no issues with tires rubbing on the lower spring perches.
843de is offline
Old 08-14-2011, 11:50 AM
nacademus's Avatar
843de never fails to help out. Good info!! Thanks!
I bet a 16" rim would provide almost the same ride. It only removes a half inch of rubber cushion and are easily found.
nacademus is offline
Old 08-14-2011, 10:13 PM
ebritt's Avatar
Thanks! There has to be at least some improvement in ride quality and noise levels with a smaller rim and more sidewall. Gonna start lookin round for some rims and see what I get. May take awhile but Ill keep yall posted.
ebritt is offline
Old 08-14-2011, 11:16 PM
Thanks nacademus & ebritt, just trying to be helpful when I can offer something up that assists another member here. A pat on the back is always nice every once and a while.
843de is offline
Old 08-14-2011, 11:26 PM
Sure there will be a softer ride with more tire sidewall..
If you can't find the malibu 843 listed, check out 'wheel vintiques' @ Summit..
sleeper is offline
Old 08-21-2011, 07:48 AM
rad white panel's Avatar
I bought 15" rims from Tire Rack and had them mount Michelin snow tires on them. They work fine just not a lot between rim and rotor.
rad white panel is offline
Old 08-21-2011, 08:13 AM
LawDog88's Avatar
As some of you may remember, I was rocking steelies and no covers. I've still got them ebritt.. if you want them, you can have them, only condition would be pick up only.
LawDog88 is offline
Old 08-23-2011, 07:49 AM
ebritt's Avatar
I didnt know there were stock 15's. Would love t o have them but too far away, thanks anyways. There may be a set in the scrapyards around here.....just waitin for me to pick them up....LOL
ebritt is offline
Quick Reply: 15 inch rims and tires???
