2006 2LT 17" Rims - Tire Variety
Old Sep 10, 2010 | 01:13 AM
jaime_g's Avatar
What other tire sizes can I fit on the stock 2006 2LT rims without having any major problems? I kinda wanna go a bit wider on both the tire width as well as the aspect ratio on the sidewall.
Could I fit up to 225s? What about 235s? I'd like to get 225/50/17s or 225/55/17s. I'm more focused on a increased sidewall width.
I've got the stock 215/50/17s. Does anyone also know the width of the stock rims? Are they 7"? 7.5"?
Thanks in advance!
These are the rims, btw:
Old Sep 10, 2010 | 07:16 AM
225/50 should be no problem, not sure about 235's....... I think the 55's may be too tall. (borderline too tall, may depend on brand) Stay under a 26" diameter (height) or you will have clearance problems up front.
I think the stock 2LT rims are 7".
Old Sep 10, 2010 | 09:52 AM
BlackknighT's Avatar
I had just tried 225/55-17s and they are a hair to close in the front when you turn the wheel. Also a little too close in rear near a piece in the wheel well. I took pictures and will post on my thread about the 2009 Pontiac G6 Rims.
Old Sep 10, 2010 | 07:11 PM
farmer52's Avatar
Stock rims are 6.5 x 17.
Old Sep 10, 2010 | 10:03 PM
X 2 & there are some members here using the 225/50/17 with no problems..
Old Sep 12, 2010 | 02:13 AM
jaime_g's Avatar
thanks
Thanks, guys. I might go with 225/50's then.
Now as if I wasn't pushing it enough, do you think I'll still be able to install a lowering kit if I get 225/50s? Like either the popular Eibach or Goldline kits?
What can I say.. I want to clean up that gap! It looks so awkward, especially in the rear. I do want to maintain same tire sizes in the front and back though so I can still rotate them.
Old Sep 13, 2010 | 01:42 PM
kjlars5's Avatar
I've been thinking of that too. If you're looking to go to a taller tire, would 215/55 x 17 fit? That is a taller size and should help you 'clean up the gap'! Does anyone know if that size will fit? I've tried searching, but maybe I'm using the wrong search terms...
Old Sep 13, 2010 | 01:59 PM
A 215/55 X 17 would be over 26" diameter so it might rub up front. (26.31" by the tire calculator) If they did fit it would be really close to rubbing on the strut spring perch. For height that seems to be the problem clearance spot.
Old Sep 13, 2010 | 02:53 PM
Ecl was running 225/55/17 for a while on "bu rims.
Mateng
Tires & Wheels
21
Apr 18, 2011 03:31 PM
Greybeard999
Tires & Wheels
Jun 18, 2010 04:59 PM
ClassicWalt
Tires & Wheels
11
Nov 4, 2007 06:46 PM
