2009 SS Wheel size specs
Old May 12, 2022 | 07:01 PM
Just confirming that sticker!
Old May 13, 2022 | 10:31 AM
PulpFriction's Avatar
Do you have Brembos? Many iwheels that will fit HHR SS non-Brembo will NOT fit with Brembos. Tirerack.com makes you select Performance Package or not, and will show just wheels that will fit. They’ll sell you 4 wheels shipped for possibly less than the price of two OEM SS used replacements, if you can find them. Not available new.
While original were 18x7.5 w/ 42mm offset, many of their listings are 18x8 w/ 35mm offset, which works out great, arguably better. Be sure you get the 5x110mm bolt pattern. Conical lug nuts from the parts store are fine for most 5x110 wheels, but you need to use what the wheel manufacturer specifies. I kinda like the stainless-capped originals for a daily driver.
Old May 13, 2022 | 11:24 AM
Dagilsrud2's Avatar
Do you have Brembos? Many if not most wheels the will fit HHR SS non-Brembo will NOT fit with Brembos. Tirerack.com makes you select Performance Package or not, and will show just wheels that will fit. They’ll sell you 4 wheels shipped for possibly less than the price of two OEM SS used replacements, if you can find them. Not available new.
While original were 18x7.5 w/ 42mm offset, many of their listings are 18x8 w/ 35mm offset, which works out great, arguably better. Be sure you get the 5x110mm bolt pattern. Conical lug nuts from the parts store are fine, but I kinda like the stainless-capped originals for a daily driver.
And that wheel size will work with the tires I already have on there?
Old May 13, 2022 | 11:57 AM
225/45 18 is the original tire size. They’ll be fine on an 8” wide rim.
BTW, use the type of nut specified by the wheel manufacturer.
Be sure to mark the bent rims BEFORE they come off the car so you know which is which.
You didn’t answer if you have Brembos. Also, do you have the original OEM wheels?
Old May 13, 2022 | 04:42 PM
I’ve run those Conical nuts for several years with SS rims , Cobalt SS rims and steelie rims
His Hot Rod
Tires & Wheels
Oct 4, 2018 10:38 PM
pjb
27
Sep 12, 2013 06:34 PM
badflt
May 5, 2012 04:04 PM
08hhrls
21
Jul 3, 2008 06:26 PM
DreamHHR
Apr 12, 2007 03:50 PM
