Anyone know a good place for adapters?
Well I figured out the wheel adapter situation. I can turn up and mill some 3/8" steel with both bolt patterns and bored center for the hub. Center caps will cover the stock lugs. I can weld a spacer between the 2 pieces for the front. One hub centered ring with the stock lugs and an outer ring with the 8 on whatever the dually wheels I end up with. Stupid easy. Cut and weld everything. True up and balance on the lathe and use the rotary table on the mill to locate and drill for studs.
Davyo
Tires & Wheels
13
Aug 6, 2011 07:46 PM
