Disable TPMS
Old Dec 14, 2009 | 07:44 PM
skyeglen's Avatar
"The hack is already out there, and it's much "simpler" than trying to signal-trick the computers in the car. Google for "TPMS bomb"... it's a small homemade PVC tank (about the size of your fist) with a Schrader valve in one end. Before you glue the thing shut, you toss all 4 of your TPMS sensors into it). After it's dry, you air it up with the Schrader valve to whatever your recommended tire pressure is. Then you toss it in the trunk or cram it under a seat. Car is happy because all 4 sensors are reading the same (correct) pressure... even if you just had 4 blowouts and are careening over a cliff."
THANK YOU, XXL!
Old Dec 14, 2009 | 09:47 PM
crazysteve's Avatar
mine randomly "die" all four of them and at different times they are just great
Old Sep 10, 2015 | 02:55 PM
Mike9679's Avatar
yes
Originally Posted by Sheverlay
Aren't the TPMS sensors federally mandated?
Check under the Tread Act.
If your car has TPMS you are not supposed to remove or disable it.
If you do so any accident you're in can been considered your fault.
Old Sep 10, 2015 | 04:59 PM
Dead thread alert, welcome to the site, but not the last post prior to yours was six years ago.
Old Sep 10, 2015 | 11:57 PM
Not only a Dead Thread Alert, but now a Closed Thread Alert too.
JazzDad
Feb 9, 2015 09:57 AM
sunset
Nov 29, 2014 12:05 PM
Jace1283
Dec 7, 2013 05:38 PM
Pinballfreak
Dec 2, 2011 08:37 AM
BlackknighT
Aug 19, 2011 07:15 PM
