Firestone Firehawk GT Tires
Old Apr 26, 2011 | 08:13 AM
tmcdaniels's Avatar
Just wanted to let everyone out there in HHr land know that I picked up a set of Firehawk GT 255/55 R16 tires and Freaking LOVE them! 50,000 mile warranty speed rating of h(113+), and they grip like god himself is holding your car on the road. I've tried to make them cut loose from the road and they just won't do it. improved handling in tight corners is an instant benefit.
right now Firestone is have a buy 3, get the fourth free promotion until the end of April. With tires, road hazard, mounting and balancing it came to around $544. these are a replacement foe the factory Firestone affinity touring tires. Dump your lame cruising tires and get some traction....and well they look pretty sweet too! they are a a lot wider than the affinities.
In sublimation.....go get some new rubber...now!!!!!:thum b:
Old Apr 26, 2011 | 08:24 AM
Just make sure you check for rubbing between the tires and the lower spring perch on the struts, anything over a 26" OD is known to cause a problem with rubbing on HHR's. A quick calculation showed you to be at roughly 27" OD, so keep an eye on things.
Also remember that at an indicated 60 mph, you'll actually be doing 64 mph, so don't make an unintentional contribution to the highway fund...AKA "I was going how fast officer?".
As far as the Affinity's go, I think you'll find they are universally hated here, awful tires...just awful.
Old Apr 26, 2011 | 11:19 AM
tmcdaniels's Avatar
How did you calculate this?. Just realized that I did go up in tires size.
Old Apr 26, 2011 | 11:34 AM
Here is a good way for you: Calibrate Speed
Old Apr 26, 2011 | 12:56 PM
Here's another handy dandy rim/tire calculator to check out too.
http://www.rimsntires.com/specs.jsp
Old Apr 27, 2011 | 01:36 AM
prod's Avatar
Hmm, those tires are big. I would double check the inner shoulder of the tires to make sure they are not rubbing on the front struts.
Old Apr 27, 2011 | 05:47 AM
solman98's Avatar
How the heck did you fit a 27" tall tire in there? How close is it to the bottom of the strut plate?
Old May 5, 2011 | 11:50 AM
tmcdaniels's Avatar
strut plate
I checked out the clearance....you guys were right. it's close, about 3/4" but the fronts are not rubbing. I also wanted to reiterate that I have 16" rims, not the optional 17" package.
Old May 5, 2011 | 12:31 PM
wheres the pic's??
HHRANDY
Jul 14, 2006 01:08 AM
