How To Fill Your Rear Wheel Wells
https://www.chevyhhr.net/forums/show...p?p=458571#135
And I should discount every vehicle that came in with ABS, ESC and Traction Control complaints/lights on/codes set, that had different size tires/wheels or had gone up to larger tires/wheels.
I guess dealers are wasting their time when we reprogram the ABS/TCS system when we install larger wheels and tires?
I'm not saying an HHR will have a problem, since I have never seen one with different sizes in the front and rear. But I have seen other models have these problems. Modifications, yaw sensors, steering wheel position sensors, speed sensors and wheel speeds sensors all come into play for these conditions to occur.
As far as the non ABS/Traction Control cars go, I think that is required. I don't profess to know anything about automotive computer systems but I think this mod would cause you grief if you had ABS/Traction Control.
And a different size wheel should effect an abs tone ring and sensor in what effect? Same goes with traction control.
As far as your TSB... that is not the same effect.
You of course can't run one size on the drivers side, then a different size on the passenger side. Perhaps changing your wheel size from front to rear or may have some effect because front to rear speeds wouldn't be the same. However, changing all around would have NO effect.
Reason why you can't go different sizes from side to side is due is also because you will screw up your trans on the front.
Customers may have one or more tires that are different sizes or produced by different manufacturers or have low air pressure sensors that are mounted on the vehicle.
So this and other similar TSBs should be retracted by GM?
I agree - but Brad?
hhrlover101
Oct 25, 2013 12:38 PM
