My tires have about met there end
Old Aug 27, 2013 | 08:57 PM
rywegh's Avatar
Running the original Affinity tire on my HHR LS 215/55/16. Need a new set of tires.
1. is there a difference between affinity touring and affinity oe?
2. Can we safely run a 205/60 or 215/60 both at the 16 height? no mods too car suspension
3. Trying not to break my family's budget got any good suggestions?
Old Aug 27, 2013 | 10:15 PM
07azhhr's Avatar
The 215/60/16 would have a total diameter of 26.16 and would either just fit or would rub the lower spring perch as 26.1 is said to be the limit for our cars. The 205/60 would be very close to the factory size. But with the 205 you will be giving up some contact patch area if you care about that.
Old Aug 28, 2013 | 01:19 AM
finnhhr's Avatar
i warmly recommend narrower and smaller rim size. i run 205/60/16 set in winter, muuuch better in old and bad roads than original set. Original size run of course better at flat new asphalt highways and on circuit...
Old Aug 28, 2013 | 09:45 AM
And do yourself a favor by broadening your search to other tire brands, there are better tires than the Affinity's out there for less money.
Old Aug 28, 2013 | 11:17 AM
215-60X16 fit just fine. Some paint may disappear from the strut perch. They are usually cheaper and sometimes a longer mileage warranty.
The sidewall markings on Affinity Touring and OE seem to be identical, but the price is radically different.
I am currently looking at Yokohama AVID Ascend 215-60X16 at MrTire 4 for around $500 with 85,000 mile warranty.
If you go to 60 series tires you will need to recalibrate your brain's speedo using a GPS device. The car speedo will be showing a couple of MPH lower than it used to.
Old Aug 28, 2013 | 11:25 AM
working on it's Avatar
Yokohamas replaced Affinities
I loved my Affinity tires, and probably would've replaced them, but Firestone values them higher than I. So I bought cheaper, but probably better tires for the money, IMHO. My thread " Finally replaced the Affinities" https://www.chevyhhr.net/forums/tires-wheels-49/finally-replaced-affinities-45381/
Old Aug 28, 2013 | 02:10 PM
rywegh's Avatar
Thanks for the replies. Yes I was already planning on different brand just wondered what the difference is between the two affinity tires.
Old Aug 28, 2013 | 05:23 PM
I never got a straight answer from a tire store. From what I can tell, price is all. May be totally wrong, but the sidewalls seem to have the identical markings. BTW, Firestone usually puts them on buy 3 get 4 sale in Oct. or Nov.
Old Aug 28, 2013 | 11:14 PM
rywegh's Avatar
Local TiresPLus is running that sale right now
Old Sep 2, 2013 | 08:53 AM
I just got around to "COMPARING" the Affinity Touring and Affinity OE on Firestone's web site.
Turns out there is a difference:
-------------- Touring -------- OE
Speed rating T ---------- S
Mileage Warranty 70K ------- 50K
Load rating 93 -------- 91
Price --------- $123 ------- $190 Round numbers/no discounts included
