Tire Pressure Monitoring FAQ's
Old Feb 2, 2019 | 01:15 PM
  #121
Did you do it with the pressure release method? Did each wheel do the single chirp and move the lamp position? Any double chirp is an error.
Old Feb 2, 2019 | 02:56 PM
  #122
cturboaddict's Avatar
no I have not. Used a standard TPMS tool first, then did it with the snap on and confirmed the IDs that way.
Did not do the release pressure method.
Old Feb 2, 2019 | 04:18 PM
  #123
It might make a difference.
Old Feb 2, 2019 | 08:21 PM
  #124
Doesn't cost to try it. But needs to be done properly step by step.
Old Feb 3, 2019 | 03:24 PM
  #125
Cat Man HHR's Avatar
Originally Posted by cturboaddict
Sensors relearn through the standard learning procedure.
I guess that meant using the Snap On tool.
When I saw you posted this I thought you did the procedure from the manual.
Old Feb 3, 2019 | 09:41 PM
  #126
Cat Man- I thought the same as well..
Old Feb 9, 2019 | 05:33 PM
  #127
Update- still dashes
So, i tried the standard release of pressure method. The car honked at each tire as its should. Bit still reads dashes on each tire with service tire monitor warning and light.
Old Feb 9, 2019 | 07:40 PM
  #128
Is this after you have driven over 40MPH for 10 minutes?
There are some Cxxxx codes that are related to the sensors, they don't set the CEL, but should cause a tire pressure light and a DIC message.
Old Feb 9, 2019 | 08:12 PM
  #129
But did it honk Twice on the last tire ? which indicates a complete & proper re-learn..
Old Feb 9, 2019 | 11:04 PM
  #130
after tire reset?
