Tires on the SS
They cleared the front strut spring pocket by an 1/8''th of an inch. But when back on the ground
If you go to the generals website the General Exclaim UHP in 245/40-18 weigh
3lbs lighter each then stock.
By the way Continental makes General tires, so i think they use the same technology as they do in there new series of tires, which are light also.
Gotta take tirerack specs with a grain of salt, they are right for the most part but they don't even list the general Exclaim UHP as a M/S tire, which its clearly molded on the sidewall on all 4 my tires.
No fit problems or rubbing with my Hankook's. I read the Car & Driver tire test along with the tire test by the German mag Auto Bild Sportscars (English Edition). Both of them rave about the Hankook Ventus V12. So far there is no comparison with the stock Michelins. I do have the 245/40-18, they are only .6" wider (.3" to each side). It is hard to beleive that the stock Michelins are a bestseller at Tire Rack. They have a very poor rating in their comparison area.
