waited just a bit too long...
Old Oct 7, 2022 | 05:41 AM
  #41
Clean and adjust the rear drum brake shoes. Most common cause of brake shakes
Old Oct 7, 2022 | 03:21 PM
  #42
jimvw's Avatar
could be but you feel it in the steering wheel mostly.
Old Oct 7, 2022 | 03:53 PM
  #43
Lonwane's Avatar
What happens is.........
When the rear drums don't get adjusted with every oil change, the front discs do ALL of the stopping.
This causes the front rotors to warp.
The cure is getting the rotors turned AND keeping the rear drums adjusted.
Enjoy
Old Oct 7, 2022 | 03:57 PM
  #44
When the rears are not working you do feel the vibes in the steering wheel. The other cause would be bad LCA bushings.
Old Oct 7, 2022 | 07:28 PM
  #45
jimvw's Avatar
4 weeks on the LCA's, never had the rear brakes open so that may be the issue. i know the fronts are getting thin. Most likely I will do front and rear just so I know it has been done.
MarkD13
Tires & Wheels
Mar 8, 2013 05:09 PM
dodger542000
Maintenance and Upkeep
Aug 12, 2012 05:57 PM
1970judge
Tires & Wheels
32
Apr 1, 2011 12:36 AM
Later
Tires & Wheels
Oct 15, 2010 02:55 AM
Lee3333
Tires & Wheels
17
Jan 26, 2009 04:58 PM
