Winter tire issue
Most of the HHR LS came out with stock 15" steel wheels. I have a set with Firestone Winterforce tires on them, great tire I found and close to a exact match for my 16" that my HHR came with.
Check out my review.
https://www.chevyhhr.net/forums/show...ht=winterforce
So I found some 15" rims locally but the ad says "Fits P195/65R15 tires and similar." My winter tires are 205/65/15. These rims should fit these tires right? Please give me good news, I have been searching for inexpensive rims for awhile now.
You might be able to find some cheap steel rims at a junk yard or scrap yard in Edmonton. There are usually a lot of recent model year Cobalts sent to the scrappers and the rims from those vehicles should be easy to find.
hey now.
i am looking for some winter tires to put on my '08 2LT.
looking to get rims and tires, so do i have to go with the same 17" rim size or can i go down to a 16" rim. been reading about peaople going down to a 15"...but is that only for the LS owners?
thanks in advance.
j
thanks in advance.
j
So, now that I have the 15" rims, I did read somewhere that changing tire sizes makes a difference in your speedometer. Just for my info, going to a smaller tire size (16" to 15") does that increase your speed or decrease it? So if your speedo is reading 60 km are you really going, say 65 km?
I run 18" wheels in the summer and 16" in the winter but the outside diameter of my tires are nearly identical. Note the side walls are taller.
If the outside diameter is less than the stock tires the speed will be more on the sped than it really is. If the tires have more diameter it will slow the speedo down.
Odds are you will vary 3-7 MPH just guessing based on most changes and speedo error. Note most are off 1-3 MPH anyway.
