Winter tire issue
Old Oct 20, 2009 | 07:51 PM
TomsHHR's Avatar
Most of the HHR LS came out with stock 15" steel wheels. I have a set with Firestone Winterforce tires on them, great tire I found and close to a exact match for my 16" that my HHR came with.
Check out my review.
https://www.chevyhhr.net/forums/show...ht=winterforce
Old Nov 5, 2009 | 10:40 PM
chocolatefonz's Avatar
So I found some 15" rims locally but the ad says "Fits P195/65R15 tires and similar." My winter tires are 205/65/15. These rims should fit these tires right? Please give me good news, I have been searching for inexpensive rims for awhile now.
Old Nov 5, 2009 | 10:52 PM
txbass06's Avatar
They should fit without any problems...
Old Nov 9, 2009 | 07:37 AM
ZTony8's Avatar
Cobalt wheels go right on.They're 15 inch steelies,perfect for winter.
Old Nov 9, 2009 | 05:20 PM
calgaryhhr's Avatar
You might be able to find some cheap steel rims at a junk yard or scrap yard in Edmonton. There are usually a lot of recent model year Cobalts sent to the scrappers and the rims from those vehicles should be easy to find.
Old Nov 16, 2009 | 08:35 PM
bobby dazzlers's Avatar
hey now.
i am looking for some winter tires to put on my '08 2LT.
looking to get rims and tires, so do i have to go with the same 17" rim size or can i go down to a 16" rim. been reading about peaople going down to a 15"...but is that only for the LS owners?
thanks in advance.
j
Old Dec 18, 2009 | 12:33 AM
My car is an '07 LT and I do have 15" steel rims that I bought to put on my car. I think it depends if it is an SS model.
Old Dec 18, 2009 | 01:09 AM
So, now that I have the 15" rims, I did read somewhere that changing tire sizes makes a difference in your speedometer. Just for my info, going to a smaller tire size (16" to 15") does that increase your speed or decrease it? So if your speedo is reading 60 km are you really going, say 65 km?
Old Dec 18, 2009 | 06:35 AM
hyperv6's Avatar
It is not the wheel size but the tire diameter.
I run 18" wheels in the summer and 16" in the winter but the outside diameter of my tires are nearly identical. Note the side walls are taller.
If the outside diameter is less than the stock tires the speed will be more on the sped than it really is. If the tires have more diameter it will slow the speedo down.
Odds are you will vary 3-7 MPH just guessing based on most changes and speedo error. Note most are off 1-3 MPH anyway.
Old Dec 18, 2009 | 01:34 PM
stephenm's Avatar
i went from the stock SS tires, to stock 16" tires for the winter.
speedometer is off by 2 miles per hour, doing 60 on the speedo is actually 62
Sileny Jizda
Tires & Wheels
13
Dec 8, 2014 09:33 PM
Pimphand
Tires & Wheels
Dec 1, 2011 12:08 PM
Hhrfyrman
Tires & Wheels
Jan 19, 2011 09:20 PM
pjb
Tires & Wheels
13
Feb 17, 2010 07:48 AM
JimDaddyo
Tires & Wheels
12
Dec 24, 2009 11:43 AM
