winter tires 225/60/16
Specs for a 225-60-16,
http://www.tirerack.com/tires/tires....omCompare1=yes
Specs fot a 215-60-16,
http://www.tirerack.com/tires/tires....XV4P&tab=Specs
I have read posts here that said the tires will rub if you get over 26.1 inches overall diameter, the 225-60-16 is 26.6 inches.. If you really want to see if they fit the only way is to mount them up and see if they rub on the strut spring perch.
