Dash power outlet not working.
Old 09-25-2009, 03:48 PM
Roadkill's Avatar
Have a 2006 HHR LS and some time ago i plug an inverter in the power outlet in the dash and blown a fuse apparently but the power outlet in the back console is still working.
I check in the fuse box and there's only one fuse labelled power outlet. Is there's an other fuse somewhere or i burn a wire or something?
Regards.
Roadkill is offline
Old 09-25-2009, 04:52 PM
Rcflyboy's Avatar
On the main fuse block under the hood, fuse #12 is for the the rear power outlet and fuse #30 or the front one. This info was found in my 2008 owners manual.
Good luck.
Rcflyboy is offline
Old 09-25-2009, 05:01 PM
JoeR's Avatar
For the '06, the front dash outlet is on the #29 and the console on the #30.
The front, #29 is a 15 amp, the rear, #30 is a 20 amp. For some reason, GM later changed the front to a 20 amp later. Who knows why, other that I've had many issues with mine, replaced the front element twice, the socket once and went to a 20 amp front finally. All is well now.
Ain't GM engineering wonderful??
JoeR is offline
andoll83
07-18-2016 12:41 PM
Pretzel
10-03-2014 10:37 AM
djw2122000
03-14-2014 10:21 AM
a76marine
02-22-2012 03:08 PM
rendon47
12-23-2011 02:26 PM
Quick Reply: Dash power outlet not working.
