Fuel Pressure
Old 01-09-2009, 05:09 PM
graydog's Avatar
Exclamation Fuel Pressure
I have a 2007 HHR 2.2 One time it cranked and cranked but wouldn't start. I had drove 50 miles and the vehicle had set for 8 hours. Two days later it started right up. Every thing was fine for two days.
I drove 50 miles to work. The vehicle set 8 hours. It took 25 minutes to get it started. I would let it crank about 3-4 seconds each time. It has now set in the drive way for two weeks. I start it two or three times a week. Every thing seams normal.
Does the 50 mile trip and 8 hours of set time tell anyone what my problem may be?
What is normal fuel pressure on a HHR? How fast should the pressure bleed off?
I have a fuel pressure reading of 55 lbs. Is that High? I am using a cheap gauge from Harbor Freight.
graydog is offline
Old 01-09-2009, 05:23 PM
ChevyMgr's Avatar
55 is okay, but you need to check the fuel pressure when it cranks but doesn't start. I think you may have a fuel pump issue.
ChevyMgr is offline
Ouz
06-13-2014 12:03 AM
car nut
12-03-2013 06:32 PM
Jfidelh
10-09-2012 06:14 AM
longhornss
13
03-08-2012 12:43 PM
Quick Reply: Fuel Pressure
