HID high beam problem
Old 05-05-2014, 09:37 AM
Knightrider03m's Avatar
I have the high/low kit from DDM tuning. The low beams work great but when I turn on the high beams, I see a change of light but it isn't lighting up the road that much over the low beams. The OEM lighting was better. Does anyone have any idea what is going on?
Knightrider03m is offline
Old 05-06-2014, 09:26 AM
Putter's Avatar
Do you have a kit number? I can only seem to find a hi/low kit on their site for motorcycles.
Putter is offline
Old 05-06-2014, 10:59 AM
skyline26's Avatar
most likely the high beams are a small LED or regular halogen bulb. The true low/high beam HID kits are very expensive..so depending on how much you paid will tell you what you have. I have the less costing kit (not from DDM) and the highbeam is like i described above.
skyline26 is offline
Old 05-06-2014, 01:33 PM
Putter's Avatar
My HID kit has a single bulb, but has the cut-off shield that drops for hi-beam. When I hit the dimmer for hi-beam, it looks like a freakin' UFO is lighting my way.....bwaaaahhhhhhhhhhh.
Putter is offline
Old 05-06-2014, 01:55 PM
My ford escape has the same hi/low kit and doesn't have this problem. Maybe the headlight housing is too small to allow the HIDs to really use the high beams.
Old 05-06-2014, 09:42 PM
Update, I had to turn one of the bulbs around to get it to work the right way. Now they are lighting up the nights sky.
royperry
01-26-2019 08:13 AM
Lee3333
08-23-2010 09:58 AM
1BadPig
Mods - Exterior
10
07-29-2009 06:17 PM
TrekMadone5.2
12-27-2007 08:03 PM
Quick Reply: HID high beam problem
