P0449 code CEL on
Old 04-05-2013, 02:59 PM
jtuchol's Avatar
Cool P0449 code CEL on
cel on pulled code ( I have a 07 with 2.4 litre) it is P0449 something about a purge valve, tried to clear won't clear, would that be the carcoal canister bad?
jtuchol is offline
Old 04-05-2013, 05:02 PM
Technical Moderator
Check the electrical connections to that thing mounted on the driver side of the engine under the air filter first.
donbrew is offline
Old 04-06-2013, 12:19 AM
PO449 = Evaporative emission control system: vent valve / solenoid circuit malfunction
sleeper is offline
Old 04-06-2013, 11:23 AM
Try the SEARCH function at the top of the page here and search for "P0449" - there are quite a few posts available (too many to list here) that give details on replacing the vent valve solenoid, checking the gas cap, the various models of the solenoid and the different wiring harness needed, as well as details on checking the main fuse block for a loose pin as per a TSB.
Good luck with it. Let us know how it goes.
whopper is offline
Old 04-08-2013, 05:47 AM
jtuchol's Avatar
thanks, I never used that search function before, it works!
jtuchol is offline
fastsuv
04-22-2015 12:32 PM
ducter
10-17-2014 07:35 AM
otiscohillbilly
02-28-2013 03:55 PM
laylowcustoms
05-15-2010 04:30 PM
Quick Reply: P0449 code CEL on
