Power Steering and tie rod problem
Old 08-26-2012, 08:29 AM
The Curly 1's Avatar
My HHR had many front brake problems with warped rotors causing vibration when I stopped. I had front brake job done on it and it was not long started doing it again. Recently I put brand new brakes and rotors on it problem solved should have done it in the first place. Now my front tie rods need replacing due to the shaking probably. Great.
My power steering light quits working and the warning light comes on once in a while. Shut off the car and restart it then it is fine.
What I think has happened is maybe there is a sensor in there that is damaged because of the looseness in the tie rods?
How hard is it to change the rack the tie rods are in?
Will that fix the power steering problem?
The Curly 1 is offline
Old 08-26-2012, 08:31 AM
Also car is a 2008 HHR with 90,000 miles, it is a great car but I should not have drove it so long with damaged rotors.
mike321
03-05-2014 10:59 PM
Grozdev
01-08-2014 05:23 AM
trails10
06-04-2010 02:50 AM
tcstoy
03-09-2008 12:50 PM
w_leroy
07-24-2007 12:16 AM
Quick Reply: Power Steering and tie rod problem
