torque converter
Old 11-28-2010, 06:26 PM
scottster's Avatar
torque converter
I have a 2006 2.4 litre and have had a engine shake at acceleration !!!! After changing front axcles and doing brakes. then checking the rear bearings and replacing rear brakes. The only thing I can come up with now would be the Torque Converter !!!!!!! Any other suggestions !!!!!!!!
scottster is offline
Old 11-28-2010, 10:25 PM
IgottaWoody's Avatar
Is it more like a shudder? Like a clutch slip? I get that every now and then..be hard to take to dealer since u never know when it will show up,,,,is yours all the time or intermittent?
IgottaWoody is offline
Old 11-29-2010, 11:53 AM
Lucky's Avatar
what speed does this happen? is it on take of from a stop or after crusing down the road on acceleration? The only time I have seen a Torque Converter cause a sudder is after the converter go's in to lock up at crusing speed.
Lucky is offline
Old 11-29-2010, 11:58 AM
Another thing to look at is the engine mounts, they can give you one heck of a shudder.
843de is offline
Old 02-01-2011, 08:39 PM
scottster's Avatar
i changed my map sensor as i got a code but no difference. i have done frt brakes rear brakes frt axles checked rear bearings everything is fine. i am still getting the abs and t/c light and still shakes on take off then peters out !!!!!! frustrating and confuses
Old 02-01-2011, 11:46 PM
Did you clear the codes after the repairs were made ?
sleeper is offline
memyselfandi
08-08-2022 11:34 AM
kbelfry
05-14-2015 01:08 PM
BQS4
03-16-2015 12:45 PM
2011hhrlt
03-04-2013 10:21 AM
HWD510
08-25-2012 10:55 PM
Quick Reply: torque converter
