Brakes
Old 11-14-2011, 05:47 AM
marylandmike's Avatar
Brakes
I was leaving work yesterday. Started car, backed out and started forward. A lady steped out and I had to stop short but the brakes didn't react. They didn't push down right. I had to forces the brakes down, which wasn't easy. They didn't even feel like non antilock brakes. I didn't hit her. They pulsed and felt "thick" for another 50 feet then worked normally. Any ideas
marylandmike is offline
Old 11-14-2011, 07:35 AM
Technical Moderator
If it's an SS, there is a TSB involving vacuum pump or reservoir.
donbrew is offline
Old 11-14-2011, 12:00 PM
Reply
marylandmike,
Have you seen the dealer for this problem?
Evan, Chevrolet Customer Service
ChevroletCustomerService is offline
Old 11-14-2011, 03:10 PM
it's an SS...I'll look for the bulletin Thanks, Mike
Old 11-14-2011, 03:37 PM
I have 28,000 miles, would these be under waranty?
Old 11-15-2011, 01:08 AM
IgottaWoody's Avatar
Welcome to the SS brake syndrom club.....do a serch and u will finds all kinds o story on this quirk
IgottaWoody is offline
Old 11-15-2011, 06:54 AM
pitbull76's Avatar
If the car is less than 36 months old it would be warranty; if not you could try asking for assistance from GM as it is a known issue, but who knows if they would help or not.
pitbull76 is offline
Old 11-15-2011, 02:24 PM
RE: marylandmike
marylandmike,
Brakes are not normally under warranty,they are known as a wear and tear item. You could check with your dealer to see what they can do. Let us know what you find out. Thank you!
Old 11-15-2011, 02:54 PM
Originally Posted by ChevroletCustomerService
marylandmike,
Evan: You might need to do a little research on the HHR SS brake problems that have been documented by Chevrolet. There is a TSB or such that deals with the SS brake vacuum issues. It covered the 2008 and early 2009 models.
The OP appears he could have an issue with this based on his desciription and some of the readers answers.
firemangeorge is offline
Oldblue
11-24-2013 11:18 AM
ImNewHere
Maintenance and Upkeep
20
08-04-2012 02:12 PM
agrandad
02-07-2012 11:13 PM
mrarff
0
01-07-2011 08:15 AM
Quick Reply: Brakes
