Should I replace worn OEM with KYB Shocks & Struts
Old 10-08-2011, 08:30 AM
JoeR's Avatar
Originally Posted by DaGrinch
I looked on the Koni web site - they don't list HHR in their drop-down for Chev models. So...... do you go with Cobalt?
The Koni listing for the Cobalt works just fine in the HHR.
JoeR is offline
Old 10-08-2011, 06:22 PM
DaGrinch's Avatar
JoeR. Appreciate the info.
DaGrinch is offline
Old 10-08-2011, 06:34 PM
jay loukakis's Avatar
I like the KYB.
jay loukakis is offline
Old 10-08-2011, 08:28 PM
ballplr's Avatar
KYB will be your best choise and yes do it all including mounts. Just my 2cents
ballplr is offline
Old 10-13-2011, 03:39 AM
Blue Rookie HHR's Avatar
Smile
Ok! I ordered the KYB struts and the mounts for the front, and a pair of KYB shocks for the rear. They should arrive by this weekend. Got it all at Partstrain.com for $260 out the door. Thank God for coupon codes! Well, hope they do the trick. I'll let you know how it goes once they're installed.
Blue Rookie HHR is offline
Old 10-20-2011, 03:53 AM
Well, I've been driving for four days now with my new KYB shocks, struts and strut mounts, and... NO MORE KNOCKING coming from the front! Car feels great! A bit firm, but that's probably because I got used to the old worn out ones. Those were so shot they stayed in any position you put them in (once removed). Absolutely no resistance!
I am set now! Hopefully nothing mechanicle to worry about till the 100k scheduled maintenance. My thanks to all you guys and all the helpful comments you put out there.
Old 10-20-2011, 10:29 AM
Glad it worked out for you. I noticed that noone answered your question about the Moog sway bar links. Did you replace those as well?
If not - MOK80252 likely is the one you need - However, check this thread as it has info about the different lengths of the links that are available for the different suspensions for the HHRs - https://www.chevyhhr.net/forums/show...t=36889&page=3
Old 10-22-2011, 03:51 AM
Thanks for the input on the MOOG MOK80252 sway bar links, whopper. It seems I don't need to replace them yet. But I'll keep your suggested link in mind if I ever have to. Thanks!
Old 10-22-2011, 04:21 AM
07azhhr's Avatar
Knock like noises from the front when turning AND going in/out a driveway or over a speed bump/hump or anything else that flexes the struts while turning is usually caused by failing strut bearings and mounts. This is a very common thing in GM vehicles.
07azhhr is offline
Old 10-22-2011, 04:33 AM
Silver11's Avatar
Welcome! I have no answers but I bring lots of questions and the fine folks here patiently answer them all. I do search but I also like interacting with this great community!
Silver11 is offline
bigtimegearhead
01-16-2014 03:28 AM
08blackHHRSS
10-26-2010 10:34 PM
intofocuszx3
02-23-2010 09:39 AM
purple haze
0
09-21-2008 05:20 PM
ngiovas
10
07-07-2006 12:09 PM
Quick Reply: Should I replace worn OEM with KYB Shocks & Struts
