Go Back   Chevy HHR Network > General Discussion > Problems/Service/Repairs > Ignition Cylinder Lock?
Old 01-13-2009, 10:05 AM   #1
richie6
Member #: 7380
Has anyone ever changed one?? How much involved??
If it's too loud, You're too old!
richie6 is offline   Reply With Quote
Old 01-13-2009, 10:17 AM   #2
ChevyMgr
Member #: 4865
Images: 706
2008 Chevrolet HHR | HHR (VIN A) Service Manual | Document ID: 1737997
Ignition Lock Cylinder Replacement
Removal Procedure
Disconnect the negative battery cable. Refer to Battery Negative Cable Disconnection and Connection .
Disable the SIR system. Refer to SIR Disabling and Enabling .
Remove the steering column trim covers. Refer to Steering Column Trim Covers Replacement .
Click the image to open in full size.
Turn the ignition lock cylinder to the RUN position.
Important: There are two retainers on the ignition lock cylinder. Depress both retainers to remove the lock cylinder from the housing.
Depress the first retainer through the lock housing access hole (2) with a small allen wrench or similar pick-type tool. The lock cylinder will back out slightly.
Depress the second retainer through the lock housing access hole (1). The lock cylinder will back out slightly again.
Pull the lock cylinder out enough to locate the second retainer to the lock housing access hole (2).
Depress the retainer though the access hole (2) a second time. The ignition cylinder should release from the housing. If not, the ignition cylinder may need to be moved in and out several times to locate the retainer correctly in the hole.
Remove the lock cylinder from the lock housing.
Installation Procedure
Important: If you are installing a new lock cylinder, refer to Key and Lock Cylinder Coding .
Position the lock cylinder in the run position. Insert the cylinder into the lock housing.
Rotate the lock cylinder in the housing. Verify proper rotation.
Install the steering column trim covers. Refer to Steering Column Trim Covers Replacement .
Enable the SIR system. Refer to SIR Disabling and Enabling .
Connect the negative battery cable. Refer to Battery Negative Cable Disconnection and Connection .
© 2009 General Motors Corporation. All rights reserved.
Old 01-13-2009, 10:24 AM   #3
richie6
Member #: 7380
Thanx a bunch..
Old 01-13-2009, 10:34 AM   #4
ChevyMgr
Member #: 4865
Images: 706
You're welcome.
