2.0 LDK Build
Old Aug 5, 2016 | 11:55 PM
  #81
Powermizer's Avatar
I showed the little plates I made to cover the Welch plugs and the front balance shaft sleeve plugs. Just for a little protection. Here is a pict of plate not installed.
Old Aug 5, 2016 | 11:59 PM
  #82
Powermizer's Avatar
Plates installed
Old Aug 6, 2016 | 12:07 AM
  #83
Powermizer's Avatar
Sorry guys. I have been trying to figure out the best way to show pictures and try to keep in order. Not doing a very good job. Bear with me. First timer. Obviously LOL.
Here is the reason for the front balance shaft block off sleeves.
Old Aug 6, 2016 | 12:10 AM
  #84
Powermizer's Avatar
Shaft that I had machined for water pump.
Old Aug 6, 2016 | 12:11 AM
  #85
Powermizer's Avatar
Cover installed and shaft protruding.
Old Aug 6, 2016 | 12:13 AM
  #86
Powermizer's Avatar
Bearing hub machined and installed for support.
Old Aug 6, 2016 | 12:17 AM
  #87
Powermizer's Avatar
Pulley and belt installed to show my idea of a belt driven water pump. The stress on the water pump will be relived substantially. Plus the water pump can be changed a lot easier. I wanted to use a electric water pump but could not find the room I needed to plumb it.
Old Aug 6, 2016 | 12:21 AM
  #88
Powermizer's Avatar
Here is what is removed for those who may not know. Yes I know the the chain tensioner guide is off. I just put it together to show all that the little chain has to do.
Old Aug 6, 2016 | 06:18 AM
  #89
hhrfreek's Avatar
That is great work.
Old Aug 6, 2016 | 06:28 AM
  #90
Powermizer's Avatar
Originally Posted by hhrfreek
That is great work.
Thanks hhrfreek. To bad that these little engines have lost some popularity. Only a few have anything to say. If I would have done this 6 to 8 years ago this thread may have blown up. Lol
