Bolting on a BNR K04-2871R
What if you have the Stage Kit and runs at 24-26 PSI now? Are you taking about those without any tune upgrade? Im interested in the 2860 series.
K04-GT2871 requires a BOV on the UICP (upper intercoooler pipe).
Its comes with hardware to make everything bolt on and space out right. You will use all you existing oil/water lines, some may need to be tweaked to fit. Cost $1200 with core
Accessories you get with K04-GT2871
New banjo bolt for oil inlet
Custom made spacer with 2 gaskets (manifold to turbo spacer)
Spacer for oil outlet tube with 2 gaskets, studs and nuts
Crush washers
The turbo that is in between the stock K04 and K04-GT2871 is the
K04-GT2860. Its is a true bolt on and uses our turbo both sides and machined to fit a GT2860 cartridge and wheels inside of it. All of your stock stuff will bolt right up, no BOV needed. Cost $950 with core
Re-tune is required with both K04-GT upgrades. Trifecta only charges a $75 re-tune fee if you already have a Trifecta tune since this is considered a major upgrade.
Link to BNR info for K04 upgrades, top part of page.
http://gonzaloherrero.com/bnr/index....&id=0&Itemid=9
Crush washers
Put the K04-GT2871 on today, went as smooth as butter.
Some minor line adjustments, but everything bolted right up.
I do have my UICP's on, but they are not bolted down as they need to come back off for intercooler swap and BoV. I also have my air cleaner tube bolted onto the compressor housing. (I didn't take any pictures)
Only thing I have left to do is switch out my factory intercooler back to my Crazy Steve intercooler and have my BoV flange welded to my UICP.
Then the tuning starts
24 psi,
I'm using Dejon 3 pc hot side intercooler pipes (I'm welding a BoV flange on), stock air box w/ KN, stock cold side intercooler pipe.
I'd be afraid to use the stock hot side piping, I've seen pictures of people that have blown them out on the K04.
So I have the intercooler already tweaked to fit.
Well got the UICP today from the welder with the Tial Q Bov welded on. The HHR SS should be back together tommorow and hopefully start the fun of tuning, logging and sending/recieving emails with updates.
