BOV replacement: Forge Motorsports
Old Mar 27, 2012 | 03:40 PM
  #151
gmdealerguy's Avatar
Been skimming through this thread. Is this something I should buy? I have 78,000 miles now and on a previous thread, I was saying that my SS does not feel "fast" or as it did when I had the upgrade installed. Sometimes it feels as if it bogs down under hard accel........anyway this was all posted in the HHR SS area of this forum https://www.chevyhhr.net/forums/hhr-ss-45/may-sound-dumb-but-40021/
Old Mar 31, 2012 | 03:48 PM
  #152
When I replaced mine the old one looked ok, but the forge works way better. I ordered the extra springs, went to the 75% stiffer one no lag with trifecta, but kept throwing p2261, so I put the yellow back in, still small lag with trifecta, but perfect with stg-1. If I were you I'd order one it comes with two springs one should work perfect for you.
Old Mar 31, 2012 | 04:06 PM
  #153
Breadfan's Avatar
So you didn't need the extra spring set? The BPV comes with yellow and green. If I understand BPV correctly, the vacuum on the the intake side after the throttle plate is what works against the spring to open the valve. There may be no instance using the stock turbo that more than the yellow is actually needed. But since I'm HPTuned you should send me the blue spring for testing just in case.
Old Mar 31, 2012 | 05:34 PM
  #154
I will have to talk with Vince first, it ran better with the blue, but was throwing a code, don't know what the answer is yet. The kit came with a stiffer one yet, red. I might have to send them to you.
Old Apr 8, 2012 | 12:45 PM
  #155
foxtrotraptor's Avatar
Got my valve in. Looks and feels way better than the stock valve. So far so good no problems. I did notice it is more quiet with the air lid on, but with the air lid off it sounds a whole lot better than stock. It does change the sound but in a good way.
[IMG][/IMG]
Old May 15, 2012 | 09:40 PM
  #156
Rainman's Avatar
Finally after listening to what everyone had to say, I finally got around to ordering the valve and SS 710 cap, cap looks awesome
The valve, the shifts are smoother, no arguments under the hood now that the BOV sheriff is in control, thats the best I can describe it.
Thanks for working out all the bug
Old Jun 18, 2012 | 06:01 PM
  #157
Rodney B's Avatar
Finally ordered the Forge Motorsport Valve from Modern Performance today.
Old Jun 19, 2012 | 12:49 PM
  #158
chonface's Avatar
after reading all the pages im still not sure lol, green for stock...but if i plan to go stage 1 can i start with yellow or switch it out later? if i can start with yellow id like to avoid changing springs later.
Old Jun 19, 2012 | 12:59 PM
  #159
Breadfan's Avatar
Don't worry about it. It is so easy to change springs anytime. Just start with the lowest (green) and work up as needed. You may never need a stiffer one than the lowest. I get occasional turbo flutter with the next one up (yellow) than the lightest.
Old Jun 19, 2012 | 02:26 PM
  #160
chonface's Avatar
ok cool ill start with greeny!
can anybody see the big ass forge diverter i had on my last car:
