GM Policy on Piston damage with Mods
Old May 19, 2010 | 09:13 PM
  #41
Snoopy's Avatar
Your post seems reasonable to me. Isn't that what WE have been saying?
Old May 20, 2010 | 05:49 AM
  #42
hyperv6's Avatar
There is the case of how it is written and how it is inforced. Not all seem to understrand the differance.
Some thing GM is just trying to get out of warranties.
Old May 21, 2010 | 11:00 PM
  #43
IgottaWoody's Avatar
........and when they start voiding because of parts that caused no damage....? Just by the fact that they are there?
Old May 22, 2010 | 08:03 AM
  #44
hyperv6's Avatar
You deal with that if it happens.
As you will note this is not common and seldom holds up unless they have good proof. It is often at the dealer level and often another dealer just takes care of it.
You might get hit by a piece of a falling Chinese space junk too but so is life.
The bottom line is odds are on your side you will be covered and if you make any mods take responsibility for them.
Also if you are going to modify have a good working knowledge on how you car works. This will protect you if something does go wrong if you need to deal with the dealer and may also prevent you from doing something that may damage other parts.
If you go in to a dealer ignorant you may have damaged something and not known it or you may get a dealer that may pull a fast one. If you want to make changes know what they will do good and bad. Todays cars are bit like the old ones. Even somthing simple as a major tires change can mess up a vehicle anymore and set codes or damage parts.
Old May 26, 2010 | 11:30 AM
  #45
camaro98z28's Avatar
Not sure if you guys didn't see where it says the stage kit can damage it as well. Sad
Old May 26, 2010 | 01:24 PM
  #46
ChevyMgr's Avatar
The bulletin does not say that.
Originally Posted by ChevyMgr
The GM Accessories power upgrade kit by itself is designed for this engine and should be the recommended performance enhancing equipment. Using the GM accessory kit with other aftermarket components could damage the engine as well.
Old May 26, 2010 | 02:38 PM
  #47
My Bad.. They cut my wires for the Stage Kit connectors so short that I cant even take the Stage Kit off and go completely back to stock.
Old May 26, 2010 | 03:00 PM
  #48
BoostedSS's Avatar
same here but why take it off
Old May 26, 2010 | 03:42 PM
  #49
Because I've had nothing but pinging issues ever since before any mods. I thought it was the fuel but I guess the OCTANE out here or quality just wont let it work right without pinging. I think a DD car needs to be left alone. I should know better. :)
Old May 26, 2010 | 05:33 PM
  #50
terryk's Avatar
I don't have any audible pinging but you can feel it surge slightly as it pulls timing every once in awhile. We only have oxygenated 91 out here.
But for the most part it's fine and runs great.
