GM Stage Kit Installed!!!
Old Dec 21, 2008 | 09:50 AM
  #91
BB540C2's Avatar
Originally Posted by gcsd3742
You can change the shift points.... It's called H/P Tuners....you should check into it....Where in Texas are you from?
I did'nt think that HPT had a tune for the auto's yet
I live in Copper Canyon Texas just north of Flower Mound.
Old Dec 21, 2008 | 12:29 PM
  #92
405HP_Z06's Avatar
HPT does support the auto HHR SS. I've done a fair amount of tweaking them on mine and it does make a difference. I currently have my 1st and 2nd gear shift RPM's at 7000 and firmed the shifts through out the RPM range.
Old Dec 21, 2008 | 12:38 PM
  #93
BB540C2's Avatar
I guess i'll be talking to Andy @ ADM next week then
Thanks!
Carl
Old Dec 22, 2008 | 03:20 PM
  #94
camaro98z28's Avatar
Originally Posted by More_Torque_More_HP
The sensor will be installed at an angle and the o-ring will be trying to seal on an angle. There is a chance for a leak.
Is that known to the dealer to shave it down?
Old Dec 22, 2008 | 03:24 PM
  #95
Here is the recommended modification for the HHR SS:
Note: When Installing Power Upgrade Kit # 19212670 on the HHR SS the TMAP for the fresh air duct between the intercooler and the engine must be trimmed per the pictures below:
Is this for the dealers to look at? I don't want them to screw mine up. :)
Old Dec 22, 2008 | 03:31 PM
  #96
More_Torque_More_HP's Avatar
This has been sent to the dealers in a bulletin. But you can print it out and take it the dealer.
Old Dec 22, 2008 | 03:42 PM
  #97
Wiring Issues
Originally Posted by turbotech
Yes Mike I can..... . .......The instructions say, and I've been told by the engineer over the phone that all the "pin terminals" are correct for both. Now pull up doc# 1913913 for the Pontiac. you will find that the map and intake psi sonsor share the 5vref and grd. Not so on the HHR. Also the gre wire is the 5vref and the tan is the grd. Now when hooked up in this way, the engine will not start. The ecm is seeing 20in of vac with key on or crank. ...... Thanks
Jared
PLEASE MAKE SURE YOUR TECHNICIAN FOLLOWS THE PIN OUT PICTURES OF THE SENSORS AND DOES NOT TRY TO FOLLOW THE COLOR OF THE WIRES. THE HHR SS WIRE COLORS ARE DIFFERENT FROM THE INSTRUCTIONS. THE SENSOR PIN OUT PICTURES ARE CORRECT IN THE INSTRUCTIONS. A BULLETIN TO THIS IS BEING SENT OUT TO ALL DEALERS.
BILL
Old Dec 22, 2008 | 03:47 PM
  #98
BILL
thanks Bill. I want the best for my vehicles and I want them to do things correct the first time. this will be the first time for me to have a dealer do performance upgrades to my vehicle.
BTW, is there any stats on the test vehicle that chevy did their work on? 0-60 times, 1/4 mile times?
Old Dec 22, 2008 | 06:56 PM
  #99
stephenm's Avatar
Where are the Dyno results?
Stock + GM Stage kit
Old Dec 22, 2008 | 07:04 PM
  #100
ADM did a test and got a lot of power.
