GM Stage Kit Installed!!!
Old Dec 18, 2008 | 01:16 PM
  #71
More_Torque_More_HP's Avatar
Originally Posted by turbotech
Yes Mike I can. First off the instructions have left one point out that Bill informed me on. His quote: "Also, I did verify that we left out the statement that the sensor in the inlet tube needs to be trimed with a razer knife in the area that will interfere with the anti-rotation rib on the HHR (Solstice does not have this)." End quote. ......
Jared
Here is the recommended modification for the HHR SS:
Note: When Installing Power Upgrade Kit # 19212670 on the HHR SS the TMAP for the fresh air duct between the intercooler and the engine must be trimmed per the pictures below:
Old Dec 18, 2008 | 01:20 PM
  #72
sorry about the picture size I couldn't figure out how to make it smaller. Maybe one of the moderators can fix it.
Bill
Old Dec 18, 2008 | 02:04 PM
  #73
405HP_Z06's Avatar
Thanks for the clarification.
Old Dec 18, 2008 | 02:32 PM
  #74
bartSS's Avatar
This will work ok if I want to get the hahn intercooler piping right?
Old Dec 18, 2008 | 03:01 PM
  #75
Yonash's Avatar
now we know about that boss removal. i think i will go ahead and do it myself before i take the kit to the dealership for the install.
Old Dec 18, 2008 | 03:50 PM
  #76
SPPD's Avatar
What will happen if this piece is not trimmed? Maybe a dumb question, but mine is being installed right now as we speak and I don't want them to screw anything up.
Thanks,
SPPD
Old Dec 18, 2008 | 03:59 PM
  #77
gcsd3742's Avatar
https://www.chevyhhr.net/forums/show...t=20042&page=5
Post #41 should help you with your ?
Hope that helps.. Turbotech is a GM tech and also a member here with the Auto SS....
Old Dec 18, 2008 | 04:14 PM
  #78
SPPD's Avatar
Thanks, I called the service center and forwarded the pics and information to him. He said he will pass it along to the tech.
Thanks everyone for the info.
SPPD
Old Dec 18, 2008 | 04:19 PM
  #79
gcsd3742's Avatar
mine will be installed next Sat. along with short throw-shifter the Electric cut-out. and H/P Tuners retune..... then back to the Dyno.....Will post up afterwards
Old Dec 18, 2008 | 05:17 PM
  #80
bartSS's Avatar
On the way home from work tonight i decided to give it another try and see how much psi i can get. It was 26 degrees and the gause got up to 23psi. Im happy
Now i just wish it was dry outside because the pull i did was in 3rd because 2nd gets no traction
