got my ic and piping in
if it's in the area where i think you are speaking of,i removed the screw there because it was barley rubing against the pipe,otherwise,no clearence problems.
The stock pipe had a screw holding it in place. The Hahn pipe doesn't have any bracket to utilize that stock mounting location. Mine rests on it... so it's rubbing off my pricey special order powdercoat and making a clanking noise from time to time. I'll probably just put a piece of adhesive-backed rubber on top of the bracket and see if the noises go away.
