got my ic and piping in
Old Dec 6, 2008 | 05:15 PM
mightymouse's Avatar
Originally Posted by XXL
Do you have any clearance issues with the hot side pipe that comes over the motor at the point where the stock pipe bolted to the bracket (roughly over the oil filter)? If so, what did you do to resolve the issue?
if it's in the area where i think you are speaking of,i removed the screw there because it was barley rubing against the pipe,otherwise,no clearence problems.
Old Dec 6, 2008 | 05:35 PM
XXL's Avatar
XXL
The stock pipe had a screw holding it in place. The Hahn pipe doesn't have any bracket to utilize that stock mounting location. Mine rests on it... so it's rubbing off my pricey special order powdercoat and making a clanking noise from time to time. I'll probably just put a piece of adhesive-backed rubber on top of the bracket and see if the noises go away.
Old Dec 13, 2008 | 01:23 PM
Chevy SS's Avatar
wheres the pics of the IC installedd..
x2!
Old Dec 13, 2008 | 01:42 PM
XXL's Avatar
XXL
I slipped a piece of adhesive-backed rubber onto the top of the bracket. That should alleviate any noise or abrasion. I did mention to Bill that he might want to look at adding a bracket there to mimic the stock mount on his next run of pipes. It would be an easy thing to add a simple tab, and IMO would solidify the 'professionalism' of the product finish.
Old Dec 13, 2008 | 03:26 PM
gcsd3742's Avatar
So Mightymouse since your thread was HI-jacked what was the final outcome of the I/C piping? pics, videos? results? I'll call you
Old Dec 18, 2008 | 01:22 PM
  #26
Chevy SS's Avatar
Pics?
foolmoon_design
2.0L Performance Tech
50
Mar 19, 2012 07:18 PM
asanti
17
Mar 15, 2010 01:11 PM
Temple of Zoom
10
Mar 1, 2010 09:44 PM
JRGHHRSS08
Feb 19, 2010 10:00 AM
en0oNmAI
2.2L Performance Tech
May 25, 2006 07:14 PM
