Help with P0017 P0016.
I went to a aftermarket company called. ZZPerformance.com for the tune. I only found a few places on the web that has parts and works on the LNF. No shops near me does any mods to the HHR.
Thanks. I noticed that the top sensor doesn't line up correctly either to the intake manifold bolt hole. You kinda have to make the senor hole wider to screw it in.
ZZP did not give me installation instructions
Charleenatas
Did the Tmap sensor go bad by itself in a year ? Doubtful. But. If you have a turbo that is failing or failed, it may have dumped oil into the charge pipe and fouled that sensor.
I would pull that lower sensor and check for any oil on it.
Just replacing the sensor won't do you any good if the turbo is puking oil.
Charleenatas
